Auto Block Reset
Auto Block Reset
jssalmon
Auto Block Reset
jssalmon
Is it possible to have my block reset automatically when I change visibilities? I have 2 visibilities both with dynamic parameters that shouldn't be allowed to overlap, but they do when I change visibilities and don't reset the block prior.
Libbya
Use a lookup in place of the visibility parameter.  Turn the visibility grip off.  Add the visibility parameter to the lookup and any parameters you want to 'reset'.  Name the rows what you had as visibility state names.  Fill out the same default values of the parameters you want to reset for each of the rows.
