Attributes, linked to Lookup-Invisibility Problem
Greetings,
I have this PLC block with Dynamic stuff in it. The IP address of this PLC card can be set by a thumbwheel or by software. I wanted to hide all the thumbwheel related objects when the IP address is selected by software. The problem: Three attributes related to the thumbwheel selected IP address stay visible when they should be invisible.
The attributes in question use fields linked to lookups.
I am running Autocad LT 2016 and have all available updates at the moment.
I am uploading the block.
Libbya
In properties, change them to Lock Position = Yes.
Oh dang! I would feel a lot smarter if I had thought of that by myself! You are the smart one today.
It is working correctly now.
Thanks for your time.
