Attribute Order
Attribute Order
christianbaileypaulsen1
Attribute Order
If i had a block with three attributes "A", "B", And "C". When i click on the block in model space and open the enhanced attribute editor the attributes are in a weird order like B,C,A. Is there a way to change the order that attributes show up in the enhanced attribute editor? Sorry in advance for not having a block for reference. Its not really one block im having trouble with, just block attributes in general. Thank you.
Libbya
Give BATTMAN a try.  Be forewarned, you might need to adjust the visibility states or actions that are associated with the attributes.
Try selecting your attributes one at a time in the order that you would like them to be when creating the block.
Nick_Antonov
Yes, you are correct, BATTMAN is the command to edit attributes in one place when the block editor is closedbattman.PNG, he can reorder the appearance in the list so when double click on the block (or EATTEDIT) you have desired sequence .
When you have a big list of attributes like in my case, what I found irritating , one cant select few attributes at the same time to move then, so I have to go one by one moving down the list, I wish in 2022 they sort this.. I know I only use BATTMAN , once in the blue moon but its time consuming to move one line at the time..
