Attribute linkage...
Message 1 of 21
I am trying to link multiple attributes to a main attribute.  The link exists; but, the value of the linked attributes are not updating when you change the value of the main attribute.  I saw some helpful ideas, but it is not successful resolution for me.  When I double click on one of the linked attributes, the Enhanced Attribute Editor opens and the value of that attribute is correct, even though I still see the default value from initially setting up the those attributes.  Please help.
Respectfully,
martinezmic
Replies (20)
Message 21 of 21
Libbya
As far as I know, the behavior you describe has never worked.  If it worked for you previously, then suspect that was an issue with your previous installs.
