Attribute Automatic values from block
DanMiddleton
DanMiddleton
I have created a block for my drawings.  It is for a single man door, with some width sizes set and the stretch parameter gets the info from the list I created and stretches the width accordingly.
What I would like to do is revise the text inside to reflect the value of the stretch parameter.  So, If I set the Width_dr parameter to 3'-0", the text updates to say 3'-0" for the attribute DR_WIDTH.  I cannot seem to find the correct value in the insert field area when creating the Attribute.
Any help would be appreciated.
Dan Middleton
AutoCAD user since 1993
AutoCAD LT 2023
Libbya
Here's a screencast.
DanMiddleton
Thank you Libbya,
I was actually getting the same result, just was not doing a regen.  Is there any way you can have the value regen automatically?
Dan Middleton
AutoCAD LT 2023
Libbya
Not while using a field.  There is an alternative, though, that does not require regen.  You will need to use a block properties table instead of lookup for adjusting the width.
As an aside - always put the basepoint at 0,0 and adjust the rest of the block to match it unless you have a darn good reason for not doing do.  There's no reason for the Width parameter to be chained.  Never chain parameters unless you need to.
