Array/stretch - Object not copied at first increment and lags 1 step behind after
asdasdfsd2
asdasdfsd2
Hello good people,
I hope you can help me. I'm creating a dynamic block which uses an array and a stretch action to repeatedly copy an object (just a circle). The issue is that the circle is not copied at the first step or increment and seems to "lag behind" at every subsequent step. How do i solve this?
I would share a dwg but apparently my work linked my account to my real name (i was not aware of this :/) and i don't want that floating around.
Thanks in advance for the help!
Libbya
When the associated parameter is 2X the column/row offset, the first new object appears.  Adjust your parameter length accordingly.  Use a chained gripless parameter for the array if necessary.
Post your block if you need further assistance.
asdasdfsd2
Thanks for the quick response! I'll look into it!
