I'm creating a wall block that changes various parameters. I have everything relatively where it needs to be; however, when I'm trying to add the last part (insulation) then I cannot get the block to work. I have the polyline for the insulation symbol and selected with a dimension and setup to array the distance it spreads vertically. It's no different than how the insulation block that I've used in the past works and yet does not work in this setup. I also tried using a dimension line as a gripless parameter and then use the array on that with a stretch dimension like I have used on the knockouts of the studs but this was no good.
I'm at a complete loss here.
