Array on the middle while stretching
kubaszymanski
Message 1 of 13
kubaszymanski
I'm looking for the solution to have this array always in cetner.  I'm using AutoCad LT.
File with block is attached
Replies (12)
Message 2 of 13
h_s_walker
See the attached drawing for guidance
Howard Walker
Left Handed and Proud
Message 3 of 13
j.palmeL29YX
Something like >>this video<<?
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Message 4 of 13
Libbya
Message 5 of 13
kubaszymanski
So simple... great! Thank you
Many thanks for you all!
Message 6 of 13
kubaszymanski
One more question, how can I make path line like this "Hidden"?
Message 7 of 13
Libbya
Turn the lines you want invisible into construction lines.
Message 8 of 13
kubaszymanski
OK, I see the problem. I use AutoCAD LT, however we have server license of full so I will make this there.
Thanks a lot.
Message 9 of 13
j.palmeL29YX
In the block editor, convert the whished geometry (lines, circles, arcs, ...) to construction geometry (command bconstruction).
In the block editor you will see this geometry dashed, in the block reference they are invisible.
Jürgen Palme
Message 10 of 13
Libbya
If the construction line creation is not available in LT, then a workaround is to add a visibility parameter and then select the path lines you want invisible and make them invisible for all states.
Message 11 of 13
j.palmeL29YX
...  or you draw this "help" line overlapping another visible line (if possible).
Jürgen Palme
Message 12 of 13
azarkovi
is there a way to do this but to not have the array skip values? the block in these examples goes from one circle to three circles when stretched. but what if i want it to go, one, two three, four circles, etc. ?
Message 13 of 13
Libbya
Yes, but depending on your particular situation it may not apply.  See attached.
