Array in Dynamic Block
Here I made One dynamic block with the Array Action. I used the same object in the different visible state for different spacing. I can make array action for the first visible state but when I do the second state then I can't do the Array action because it says the object is already selected. please give me a solution or Is there any other way to do this block
I attached the file for the block. please see the visible state named Flat Lens & dome Lens Plan 12" I want to do like this but cant do in other visible states.
Libbya
Copy the item in the second visibility state.  Make sure the original item is not visible in the new state and that the new item is visible.
