01:14 AM
- Mute
- Permalink
- Report
Hi guys
I am having some trouble with constraining a door opening arc to a scaling block of doors. I would like to constrain the arc points to a scaling door block.
The center point of the arc is fixed, but when stretching the width of the door the arc should slightly rotate.
I don't know how I should constrain this, there are no tools for scaling, stretching arcs in dynamic blocks.
Red, blue and gree lines shows how the arc rotates when I strech door. The angle of rotation is variable 😐
I have straight auxiliary lines coming out of the center of rotation and they extend correctly. How do I constrain the arc to them?
Regards
