- Mute
- Permalink
- Report
I thought it was possible to scale arcs but it seems not.
In the attached blocks, the outer arcs do not scale correctly & I can't understand why, when the inner geometry does scale correctly.
Does this need constraints, or can it be done solely with parameters/actions?
There are two blocks, because I thought that the location of the centre point might be the issue (the 01 version being the preferred).
There are 3 widths (100, 200 & 300), the screen grab below show the 200 wide, the yellow lines are what is should look line, the green & red are not behaving. The black lines scale correctly.
