Arc (Door Swing) In Dynamic Door Block Is Not Scaling Properly
mcboudwi
Observer Observer
mcboudwi
Observer
Observer
I've found similar problems in the forum, but none of the solutions have fixed my issue. I have a distance parameter to change the size of the door and a scale action on the door swing. The arc does not scale correctly when I change the size of the door. I included the file I was working on. It has two doors that I am going to put on different visibilities once I figure out the problem with the scaling. Thank you!!
j.palmeL29YX
BTW: Your arc is placed/drawn not precise. Check (and correct) the position of the center point and the endpoints of the arc.
Jürgen Palme
mcboudwi
Observer
Observer
Thank you! This was very helpful!!
