anyone interested in helping create a simple dynamic block?
MKH-VB
Message 1 of 11
MKH-VB
Guys....I have tried to my hearts content to try to figure out how to do this to no avail.  I have a block here called driveway apron, (inside this driveway dwg) and would like to insert it, and be able to stretch it to fit the field conditions.  If anyone would be interested in looking at this I'd be eternally greatful!  I will upload with this thread. thanks
mkh
Replies (10)
Message 2 of 11
j.palmeL29YX
show us some examples how the block should look after stretching.
Jürgen Palme
Message 3 of 11
MKH-VB
looking at the block, this is a driveway apron.  The "X" distance will be variable from 9 feet to 30'.  The "Y" distance just stays the same.  So all that needs to happen is the width stretches.
mkh
Message 4 of 11
h_s_walker
Look at the image below
Howard Walker
Left Handed and Proud
Message 5 of 11
j.palmeL29YX
attached a first try.
[EDIT]:
I think you can edit the block now to your requirements.
Jürgen Palme
Message 6 of 11
MKH-VB
Sorry guys...I should have been more detailed....I have re-uploaded.  The entire side will move. See attached.
mkh
Message 7 of 11
j.palmeL29YX
That's why I asked above 😉
Next question: Stretch to one side only or stretch symmetrical to both sides?
Ok, >>here<< I show you both variants.
At the end you can define the minimum and maximum values for the Linear parameter in the properties window.
(in the video I pointed to where you can type it. )
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Message 8 of 11
MKH-VB
just the one side stretching is fine!  Looks great.  Sorry about the confusion 🙂
mkh
Message 9 of 11
MKH-VB
Did you ever upload that block you did that stretched on one side?  I saw it in the video but can't find the dwg. Thanks
mkh
Message 10 of 11
j.palmeL29YX
No, I didn't upload the block. You can create it yourself following the steps which are demonstrated in the video. (And at 1:10 you can stop watching the video ... )
Jürgen Palme
Message 11 of 11
MKH-VB
got it...I appreciate the tutorial!
MKH
mkh
