Another Dynamic Door Block Question
Greetings and salutations from Texas y'all!
Attached are a PNG file and the actual file of my Dynamic door block I would like some suggestions or help with.
The issues I'm having are as follows:
1.  Since most of the parameters are based off of the door width parameter, it fails miserably if the Dr Wdth is not the first parameter set. Any way this can be overcome?
and
2.  I would like to set both the hinge side and strike side of the frame size from the single Frame Thk and Frame Wdth  parameters on the hinge side of the door. The problem is that I can not get the strike side Frame Thk to stretch in the 0 direction as the hinge side Frame Thk parameter is stretched in the 180 direction. The width of the Frame Wdth will be consistent for both the hinge and strike sides of the door. Is it even possible to do this?
Any help or suggestions are greatly appreciated.
Thanks y'all,
David
Libbya
Screencast shows step by step the diagnosis and repair of the various issues in the block:
Libbya,
Very cool!
I should be able to fix my block with this.
Thanks a lot,
David
