Adding specific block dimension outside increment?
Hi friends
For the attached block representing a conveyor, how do I add a specific dimension that lies outside the given increment? I need the block to have an increment of 150 mm between the length of 1125 and 7125 mm, but I also need 750 as an option. I'd rather not use list to avoid writing a lot of distances, but I'm thinking it could be possible with double lookup somehow, but I'm not completely sure how to use it...
Thank you in advance 🙂
ojuris
try attached file
I don't know if I understand correctly
h_s_walker
As @ojuris has said I don't understand your problem 750 is a multiple of 150
Howard Walker
Left Handed and Proud
750 is not an increment if your starting number is 1125. May have to have a second parameter to set it to 750.
Libbya
I believe a list is the easiest way to do it despite the effort involved in creating the list.
