10:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am in the process of making our existing non-annotative dynamic blocks into annotative blocks. We use the tool palette for all of our block customization needs for every block. This is AutoCAD 2020.
Here is my workflow:
- Open the DWG file for the block from the Files Explorer. This makes it to where the block is opened immediately into the Block Editor.
- Make some improvements to the block as needed while also updating the system variables to match our template DWG.
- Change the property for Annotative from "No" to "Yes".
- Save and close the DWG.
- Update the block's tool image in the tool palette while making sure the properties for the block are set to 1 as overall scale and no alternative scaling methods selected.
- Open our template file which is already set up for annotative blocks.
- insert the block to test it.
At this point, the block changes the property from annotative to non-annotative. However, I have made multiple blocks using this method and only some of the blocks are behaving this way.
