Annotative Block Changing Size
sneenanKFX38
sneenanKFX38
I'm having issues with a dynamic section symbol I've made. I would like it to remain a visible and properly proportioned size when I switch between model space and layouts/viewports. I generally work in 1-1/2"=1'-0" scale in model space, but that's not always the case for my viewports. When I look at it on model space the numbers and letters shrink dramatically in comparison to the circle. What can I do to avoid this? I've attached the block and some screenshots. TIA!
Libbya
I don't have time to look at your block, but wonder if the attributes are also annotative.  If they are, then they should not be within an annotative block.
sneenanKFX38
Thanks for the tip! I'll take a look deeper into it, that may be the case
Addendum: That does not appear to be the case, unfortunately.
Libbya
In model space either turn on the option to automatically add annotative scales or select the block, right-click, and 'annotative object scale'>'add current scale'.
sneenanKFX38
That will bog down the drawing as it will add the scale to every annotative object in model space. The drawings I work with are already fairly large and I would like to avoid increasing the workload on my hardware. I was hoping I could add my usual scales to the original block and it would be pulled through my tool palettes but that's not working either.
Libbya
I typically keep the 'add scales' button activated (unless there is a specific reason I do not want scales added) and have worked in some large fully annotated files without any perceptible slowing down of processing.  Is your workstation ancient?  How often are you adding a bunch of annotative objects and then changing scales for the first time?
Regardless, you can indeed add the necessary scales to the individual block prior to making a tool palette tool from it or select just the blocks you want to add scales to and do them as a single batch (although that would take considerably more time than the processing required for automatically adding the scale).  Pick yer poison.
Hope that helps.
