Annotative attribute position in block
- Mute
- Permalink
- Report
I'm trying to make a simple gridline-block with dynamic annotative bubble to label them.
The bubble itself is an annotative nested block - cause i only want the bubble and label to scale - whose position is movable with a simple move and stretch action.
I'm struggeling with the position of the attribute. It has to keep it's position in the center of the bubble, rescaling acentric.
I tried to add different annotation scales in the block itself and move the attribute for each scale. Still when importing it in a new file with no annotation scales defined it doesn't work properly, unless you edit the block en attsync it (file attached)
Is there another way to keep the annotative attribute attached to a position for different scales dynamically (acentric)?
I'm not familiar with constraints, is this an option?
Thx
