Annotation Block with Dynamic Area Field with Multipliers
Crass
Crass
Hello! I want to create a tool where I can click on a hatch or closed polyline and then a block would be generated that can be inserted wherever you want by the user. The block would contain the area (SqFt in this case) of the hatch. It would be dynamic and associated with that hatch so that when the shape changes the area in the block would also update. In addition, I'd like to create a multiplier (formula) accessible through a dropdown in the block which would give a different value based on a formula using the multiplier and hatch area. The goal is to rapidly determine plant unit quantities based on area of planting bed x spacing of plants using the formula and have that all visible and dynamic in the annotation block.
Does anyone have any suggestions on how to start with this project? Maybe there is already a block or LSP out there that already comes close to this that I can modify?  Thank you!
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
neaton
I think a LISP routine would be better for this. Search the AutoCAD Customization forum and see if someone has already done something similar.
~Nancy
