Hi All
Would really appreciate anyone helps on this problem I have with an aligned constraint parameter. I have managed to address most issues relating to changing the overall width between stair strings however I’m having a problem changing the length of the tapered step/tread using an aligned constraint parameter. I think I need to enter an expression relating to the length of d4 maybe.
I have attached a DWG for you to have a look
Cheers
@Anonymous Entering expression will not work in this case you have to do it manually. i have attached you r block with some modification hope it will help you.
Hi @Anonymous
I can not understand what exactly you want, but when I open the block I saw many constraints In my opinion you can replace the parameters instead of these constraints.
please see the attachment file for this solution and please feedback me if it helpfully.
