OS: Windows 10 Pro
AutoCAD version: 2021
I am attempting to update our standard symbols for valves so that when they're placed over a line as exampled below, the wipeout will hide the line under the symbol.
The existing valves are already dynamic blocks with action parameters that seem to operate without consideration for any wipeouts that I create in the block editor. For example: After I create the wipeout (non polyline version) in Block Editor, save, and attempt to rotate the block using the attribute symbols in model space, the wipeout doesn't rotate, flip, etc. when the block does. However, when I use the rotate or mirror COMMAND, the wipeout will change with the block. How can I make it so my wipeout is linked to the action of the block's parameters when I use them?
(Dynamic block rotated with the rotate parameter. Seems to change the block and not rotate the wipeout)
(dynamic block as seen in BE)
(Dynamic block with wipeout (green) sent to back)
I have also tried turning the triangular portions of my block into polylines and converting those to wipeouts without erasing the lines but that seems to break the action parameters that are already set to the block.
Additionally, there are other visibility states associated with this dynamic block that I would also like to include wipeouts with. Will I have to create a wipeout for each visibility state? If I create the rectangular wipeout and try to switch to a different visibility state in model space, the block seems to be broken/hidden by the wipeout I created.
I'm sorry if this question is confusing at all, I am new to wipeouts.
I've come across suggestions of using the invisible ink method with color #255 but haven't found a step by step tutorial on how to go about doing that in lieu of using wipeouts.
Thank you in advance for any suggestions!
