Adding dynamic block from excel file
maria.stachura
Observer Observer
maria.stachura
Observer
Observer
Hi! 🙂
I am young student just starting my way in lisp coding and I need a little help.
I am trying to add from excel file dynamic blocks to dwg file, that will appear in certain locations writen in csv/xlsx file. It supposed to look like this:
The tricky part is that I have to write a LISP doing it automaticlly. Can someone please help? 🙂
Thanks in advance!
In attached files I am adding excel file with sample coordinates.
TheCADnoob
Check out the Lisp forum
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Also i would look into
https://www.theswamp.org/
CADnoob
jvasUUKFX
If you need to create the block from scratch, that's beyond me (from LISP).  If the block definition already exists within the drawing file, then that's easier.  You should be taking parts of the sample LISPS already included with AutoCAD and from the web to do find the code sections you need for your algorithm.  The tasks you are needing to do are:
  • open excel file;
  • make list from excel file data;
  • (looping from your list) insert (pre-defined) dynamic block at user-specified coordinates;
From there you have one of two options.  You can make your LISP either assign the block attributes at the time of insertion, or you can make your LISP use the ENTLAST command inside of your loop to select the block and re-attribute it.
There are sample LISP files installed with AutoCAD which can do much of this.
DumR0
you need learn VBA programing for that not lisp
jvasUUKFX
Not exactly true.  They don't need to learn VBA.  It's just a lot easier for dynamic blocks.  But there are things that LISP does better than VBA.  And block attribute handling is one.
VisualLISP handles dynamic blocks, clumsily.  The best documentation for VLISP commands affecting dynamic block properties are actually found on the Bricsys website for BricsCAD (https://developer.bricsys.com/bricscad/help/en_US/V22/DevRef/index.html)
The following line is a simple (and I use the term relatively) example of how to get a dynamic property (vla-getdynamicblockproperties) from a block (stored in variable "venam") and sets that value to a variable (pblst) for later use:
(setq pblst (vlax-variant-value (vlax-get-property (nth 0 (vlax-safearray->list (vlax-variant-value (vla-getdynamicblockproperties venam)))) "Value")))
Setting dynamic block values is much more complicated, because you need to know how to create and modify safe-array objects.
In OP's situation, I suspect that the block definition already exists and they are simply setting attribute values.  So, this wouldn't be an issue.
