The reason I haven't done that is, because I cant figure out how to. Unfortunately, it isn't as straight forward as this lookup changes the width, this lookup changes the height, etc. I am using double lookups to control the visibility, scale and quantity of components all at the same time. Also, the idea of the lookup was that I am able to name each position of the parameter, opposed to having the options be entirely dimensional. It is a little more user friendly for my colleagues this way.
It isn't a huge issue if there isn't a way. It would have just been nice to remove this huge list from my drawings and replace it with a table.
I created the block to combine a list of 52 blocks, that are typically used alongside one another, into a singular block where you simply select the quantity for each component. But as you see, this long list isn't pleasant to look at and takes up a large portion of my screen. all of the text is on a layer that doesn't print, but it is a lot of clutter for while I am drawing. Plus the fact that I have had to label them all individually, due to Lookups not displaying the parameter name. This means that there are snap points everywhere and it can be irritating having to switch them on and off all the time.
These are all minor issues. But when you have put a lot of time and effort into a project, you want nothing more than to feel like it is 'right'. All of these small things bug me and they are all caused by that eyesore of a list.
Oh well, I guess I am stuck with it! Thank you all for your help anyway though. I appreciate it very much!
Nik.
