Add auto dimensions inside dynamic block
zvigad
804 次查看
6 条回复
2 条消息(共 7 条)
zvigad
I made this dynamic block which do auto spacing between the center of the circles.
I'm trying to add auto dimensions between the center of the circels also but without sucsees.
Can anyone help to find the way to add auto dimensions to this dynamic block?
Thanks for the help.
0 个赞
已接受的解答 (2)
805 次查看
6 条回复
回复 (6)
1 条消息(共 7 条)
hak_vz
Look for a solution in Dynamic blocks forum
Miljenko Hatlak
0 个赞
3 条消息(共 7 条)
mlehky
By autodimension you mean like a text with the dimension? If so, you could change the MOVE actions for STRETCH and just put a dimension between the circles and hide the lines. Its not perfect and leaves some points in, but it automatically updates as you stretch and works alright. I have attached a sample below your dynamic block.
0 个赞
4 条消息(共 7 条)
MMcCall402
已接受的解答
In each visibility state add an associative dimension between the circles.  They will stretch on their own just by being associative. I added some to the first 4 or 5 visibility states in the attached file.
I also included another way to do this block that allows for a maximum spacing to be entered in the blocks properties and it will adjust the spacing and number of circles on it's own.  (including the gap to the first circle)
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
0 个赞
5 条消息(共 7 条)
zvigad
已接受的解答
Thanks for reply.
The solution is associative dimensions as you said.
I used it between the circles and from the base point to the first circle.
For the last circle to the end I used Strech prameter.
It works perfect.
0 个赞
6 条消息(共 7 条)
Amriya_Exe
Hi bro my work is also similar to yours. my line length is 39.900m I want to add 4 circle to every 4.9m then 4 to 4.83m with dimension can you send any tutorial or idea to make block like yours with dimensions.
0 个赞
7 条消息(共 7 条)
zvigad
0 个赞
