- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I wanted to see if anyone can help me with this block, or want to take a crack at figuring it out?
I am attaching a CAD file with the block, and a snip of the alignments I want to accomplish.
The Block with the arrays are fine, it is for crosswalks and the array keeps it spaced correctly.
There is already an alignment feature with aligns it with the cyan highlight (parallel to the travel lanes), but I also want to be able to rotate the array in a way where it is centered across the yellow highlight (path between curb ramps).
In the snip, the left side is how the block currently works, but the right side is how I want the block to work (bars parallel to travel lane, but array along pedestrian path).
Thank you in advance for any advice and help!
