http://usa.autodesk.com/adsk/servlet/index?id=3245154&siteID=123112
Like Volo View, new Autodesk DWF Composer provides easy-to-use DWG and DWF
file viewing and printing. It also provides improved markup tools to easily
add redlines, annotations, and other information to the design set. But with
Autodesk DWF Composer, markups don't stop there. Now your changes are
automatically tracked by Autodesk DWF Composer and can be viewed within
AutoCAD software, allowing the designer to incorporate changes or submit for
further comment. That's why we call Autodesk DWF Composer the "round-trip"
review application.
Thanks to tight integration between AutoCAD 2005 software and Autodesk DWF
Composer, all redlines and markups are listed and easy to track. Taken
together, these new features greatly improve the speed and efficiency of the
design review process, from beginning to end.
When you use Autodesk® DWFT Composer for the first time, you'll be amazed
you ever worked without it. This entirely new release delivers tons of
timesaving features to speed design reviews, including:
a.. Seamless integration with the AutoCAD® 2005 family of products,*
allowing markups to be overlaid on the AutoCAD file to reduce errors and
cycle time
b.. Complete sheet set organization that allows you to add, delete, and
reorganize DWF files and sheets, including timelines, images,
specifications, and more
c.. Powerful status tracking tools that give the history, as well as
status, of reviews
d.. Intuitive review, measure, and mark up tools to quickly and easily
communicate comments digitally
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
