Updating AutoDesk DWG TrueView 2014
I need to push an update to several hundred installation of Autodesk DWG TrueView 2014. The only update I can find is a full install of Autodesk DWG TrueView 2017 or 2018. The installation files equal 800 megabytes. We believe that the limitations of our custom tools won't handle the size of the full installation.
Is there an update we can download to update Autodesk DWG TrueView 2014 to 2017/2018 versus a full install?
pendean
Community Legend
Community Legend
There is no such thing as an "update" to DTV2017/2018: it's a full program install.
m_latz
What you can do is to split the Autodesk TrueView 2017/2018 installation package in two parts.
1st part for the prerequisites (VC++ runtimes, DirectX, .Net Framework, etc.), 2nd part the main TrueView installation.
Then the main TrueView installation is about 400/470 MB (2017/2018), the size of the prerequisite package depends on your base installation of your pc's.
i.e. if all your pc run .NET Framework 4.6 or higher you do not need to distribute this, etc.
regards
Markus
Type a product name
