Hi everybody!
Using DWG TrueView (2014, running under Win 10 (64bit)). When I try to print a drawing it doesn't show my default printer (an HP-T1100 (with current Win 10 driver), which is set up as the default printer in options in DWG TrueView) and won't print. but if I convert the file to a PDF it prints ok. I would like to print the files directly without having to convert them to a PDF. Does anyone have a fix for this problem?
