I am relatively not tech savvy. I am trying to install DWG TrueView 2007. I keep getting error 1935.
I need to view drawings and print them to PDF without the Autodesk information at the top. 1. Is there a newer viewer? and 2. How can I finish this install? (Or any install that will do what I need to do.)
Can someone help me? Thank you.
2019/2/21:09:08:48 Autumn LAPTOP-JROV8P1V === Installation started on LAPTOP-JROV8P1V by Autumn ===
2019/2/21:09:08:51 Autumn LAPTOP-JROV8P1V Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 5.0.17134.590
2019/2/21:09:08:51 Autumn LAPTOP-JROV8P1V Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2019/2/21:09:09:14 Autumn LAPTOP-JROV8P1V Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-1
2019/2/21:09:09:14 Autumn LAPTOP-JROV8P1V Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 6.2.17134.1
2019/2/21:09:18:01 Autumn LAPTOP-JROV8P1V Install DWG TrueView 2007 Failed Installation aborted, Result=1603
2019/2/21:09:18:01 Autumn LAPTOP-JROV8P1V === Installation ended ===
Solved by pendean. Go to Solution.
