Message 1 of 9
Error converting any file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
whenever I try to convert a .dwg file to anything, I get:
"The files listed below could not be saved due to a sharing violation or disk write problem"
The file that is named here is the source-file. The source-file is accessible (local harddisk, also tried local USB-stick) and readable/deletable.
The destination is also accessible. I tried saving that into a zip, the zip is generated but the "Conversion.txt" inside the zip contains the very same error-message.
I tried multiple versions of DWG TrueView, to no avail.
d0.dwg is one of the files, I tried to convert.
Has someone any clue as to why that could potentially happen?
Best regards
Robert
