API to publish to PDF in Autodesk DWG TrueView
a_frattiniWQ59L
Observer Observer
a_frattiniWQ59L
Observer
Observer
exist API or batch command to publish to PDF in Autodesk DWG TrueView ?
pendean
Community Legend
Community Legend
@a_frattiniWQ59L wrote:
... or batch command to publish to PDF in Autodesk DWG TrueView ?
a_frattiniWQ59L
Observer
Observer
@pendean ,
your solution need to open Autodesk DWG TrueView and add dwg file for batch plotting. I'm looking for a solution that work in background like a .bat or a program that use API.
pendean
Community Legend
Community Legend
@a_frattiniWQ59L I suspect you are in the wrong website for your query if a search in the forum went no where.
APIs are offered and discussed here  https://aps.autodesk.com/design-automation-apis
a_frattiniWQ59L
Observer
Observer
@pendean ,
I asked if Autodesk DWG TrueView that is a viewer, it supports some type of programming tool.
