I am noticing some short, fictitious lines appearing on my screen. The show up at vertices and seem to remain in place at the final endpoint. Is this a feature I can turn off?
Thanks!
Thanks!
Attached is a sample .dwg. I have removed much of the bulk but any setting should be saved.
In the event that it matters, I am using 2013 Full.
1. you are in the wrong forum, this is for DWF files and the programs that read them.
2. I can't seem to replicate the problem in R2016 here: is this a sudden new problem for you, or is this a first for a contour file from another user or vendor or software?
1) Oops! If you would be so kind as to direct me to the correct forum, that would be much appreciated.
2) This is a new problem. I am current on all updates. I updated following the problem but observed no improvement.
To clarify, these truly are fictitious lines. These horizontal segments cannot be selected and there is no vertex associated with the line. I have made an additional observation - when I start a polyline and undo a segment, the previous segment still prints to the screen even though my new polyline starts from the previous vertex. All these problems point to a graphics driver in my mind. Thoughts?
I also use 2013 LT and 2016 Full (for a myriad of uninteresting reasons). This problem does not carry over into either of those versions.
Interesting - I created a new user with admin rights and did not experience the problem. What does that mean?
I use a lot of third party plug-ins. One of the packages is produced by a company that was bought out - but the new owner has not released updates that work with newer versions of AutoCAD so I am stuck with 2013 (hopefully only temporarily). I use 2016 for other third party packages that are still being updated regularly.
Thanks for the help.
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
I found a workaround, although it isn't very feasible for day-to-day use. I have expended a great deal of effort relative to the size of the problem and am unwilling to continue chasing down the source. Simply put, I am living with the issue which is more of an annoyance than a real problem.
