We have blocks embedded with “Wipeout Plines” to mask the background information when the block is inserted and placed over other entities. The DWF file views fine, and masks the objects correctly; however when we print the wipeout areas are filled with solid black, covering the source block. This does not happen in the Plot Preview, only when printing!
This same problem occurs when creating PDF files.
Any ideas?
Software Usage:
ACAD MAP 2006
DWF Viewer 6.5
lcortez
Cox Communications, Inc.
Larry.Cortez@Cox.com
