The sample should build and you should be able to use it via the command
line. If you want it to work from within VB, then you'll either have to
shell out to a system call, or create a C++ COM wrapper around it.
"Bob" wrote in message
news:0079D4FD60FB1AAEF66DAF5BD9CA708C@in.WebX.maYIadrTaRb...
> Thanks for your quick response.
> I was thinking of merging two dwfs and not saving the result, so the
actual
> files wouldn't change. I use mergedwf in Whip! now.
> Do I need to know C++ to use the sample in the toolkit? I only know VB.
> "Jeffrey Klug (Autodesk)" wrote in
> message news:68D7AAB982312DD8189F75E151DEC6E1@in.WebX.maYIadrTaRb...
> > Thanks for the feedback. The Express Viewer is intended to be a pure
> > viewer, and as such is slated to remain read-only. No authoring-type
> > functionality like you describe is planned for the free viewer at this
> time.
> > Merging dwfs can be done offline using a sample app provided in the DWF
6
> > toolkit.
> > news:EC3AA0E7A9102C31B5864D6BB14A3312@in.WebX.maYIadrTaRb...
> > > The API in 3.1 is looking good!
> > > Can we get the ability to add text and merge dwf in the next version?
> > > Thanks,
> > > Bob
