refedit multiple blocks
!Dalton_Goodwin!
!Dalton_Goodwin!
Hello All,
Is there a way to refedit multiple blocks? Or change the blocks layers to zero without having to go into the block editor?
Thank you,
DaltonGOO
3wood
You can try CHZ20.vlx
Settings as below:
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did @ 3wood suggestion help?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
