Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
I want to make a dodecahedron
4 REPLIES 4
nwj2000
5707 Views, 4 Replies
Hi There,
I want to make a dodecahedron. Has anyone got any ideas how to do this with fusion 360?
I have seen examples with other programs whereby you create a pentagon sketch, patch this to create a surface, copy and paste, then apply edge constraints to form the 3D shape, stitch it and hey presto. I'm sturggling to to this with Fusion 360.
Nick
4 REPLIES 4
TMC.Engineering
in reply to: nwj2000
Well I did it a different way but it looks right to me.  I made it a solid in model mode.  you should be able to download it from teh link.
Extruding a pentagon with a draft angle is the key.  I will work on makeing a screencast.
http://a360.co/1M80wF8
Using some trig from the internet I wrote some expressions that can be found under Modify/ Change Parameters
Change expression "a" (the length of an edge) and the dodec will resize.
I am not sure why the sketch is not fully constrained (it seems to be but is not black), maybe someone else can figure that out.
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
The Screencast cleaned up the model flow a little
http://autode.sk/1RFueRV
Timm
Engineer, Maker
nwj2000
in reply to: TMC.Engineering
Great, thanks Timm!!!
All the best,
Nick
TMC.Engineering
Your welcome.  If you don't mind, please mark lotion as accepted.
thanks
Timm
Engineer, Maker
Technology Administrators
