Help with my first project
- Mute
- Permalink
- Report
I'm planning on getting into CNC as a hobby, but the need of a new roof has delayed my building my own CNC machine. I'm trying to learn Fusion 360 in the meantime. I'm completely new to this stuff, and I've found the tutorials move WAY too quick for me to catch what they are doing. It took me about 20 minutes to create a rectangle in the size I want, then another 20 to put a cut out in it.
I want to build a harmonica comb. Here's a picture:
Here is the design strategy I wanted to follow (but can't seem to because I don't know what I'm doing.)
- Create a rectangle of the proper size, centered on the Y axis (so when I put the middle tooth of the comb in, its centered.)
- Create the proper width slot, then place it on the comb.
- Create 9 duplicates of that slot, and space them evenly along the edge of the comb
- Edit the height of each slot
- Place the holes in the proper position
- Round over the corners
- Extrude to the proper height.
I'm having problems moving something to a particular measurement. For instance, I want the first slot to be 14.18 mm from the left edge. I can measure where I put the slot, and I can move the slot, but I can't figure out how to move the slot to an exact location.
Am I going about this the right way? Any suggestions? I'm on a Mac, if that helps.
Thanks!
Phil
