Get latest not working in last release.
Since the last release happened, the get latest command pulls out a random stored version of some parts in assembly files. Even if you chose a specific version of that part, the program just pulls out one of the random versions stored. Any idea what might be going on here.
bespenship
Hi Amenotepia - I would like to isolate the issue you are seeing so we can fix it.  Could you share your design with me?  You can reach me at brent.espenship at autodesk.com .  From your description, I assume you have a referenced component in your assembly that was changed outside of the Fusion design where it is referenced, or you simply want to use an earlier version of the referenced component?  I have been looking at those scenarios on my end and am not seeing the same problem, so access to a design with the issue would be a big help.  If you can't share your design, I understand, and we will continue to try to replicate the issue on our end.
Thanks and cheers,
Brent Espenship
Fusion 360 Quality
Macbook Pro retina - MacOS X 10.11.5 (main)
WIndows 7 Notebook
