Is there a way of finding and zooming into a specific feature in sketch? I have 3 failed target features, probably as a result of a referenced component changing - they have names such as "Project24", which I assume is a result of a projection from another sketch, body or component onto the currently opened sketch. But... there is no obvious way of finding and zooming into the offending feature. Normally the error shows as yellow; I have numerous projection points and lines which makes the drawing very cluttered. So it's possible that the yellow is obscured. Anyone have any ideas?
Peter
Hi @pludikar
Thanks for posting! The yellow is likely obscured if you have multiple projected sketch elements. Unfortunately, we do not have a tool to locate the sketch elements causing errors - it would be a great addition to the Fusion 360 Ideastation though!
One thought is that you may be able to find the error by holding down the left mouse button while selecting sketch elements. This will bring up a list of any overlaid sketch elements and may help you find the correct projection to delete.
Hopefully this helps! Please let me know if you have any questions!
