I've got a few fixtures to make. All of the features (except one) are identical. On 2 fixtures, it's a hole for a 1/2" dowel. On the third, it's for a 5/8" dowel pin. Do I need to make multiple part files, for each variation, or is there a simpler way?
Solved by Oceanconcepts. Go to Solution.
You can copy and “paste new” your components, then make the hole modification. That would give you multiple components, but not necessarily multiple files.
Some discussion about this in this thread: http://forums.autodesk.com/t5/design-validate-document/how-to-make-a-family-of-similar-parts/td-p/58...
