Autodesk Print Studio Printer Settings
Message 1 of 23
I have been using Autodesk Print Studio for the past weeks and I have grown to love it even with my reprap using the printrbot profile as the profile. The toolpaths run fast and clean and are very well built. Though there are certain setting which I think should be opened to modification for printers. Maybe the option to modify these could be an advanced feature only available upon the users choice to see the "advanced settings!"
  • Change Filimant Size. most filaments have slighlty less than the predicted size.
  • Change Retraction Amounts. One set Value rarely works for every machine, even if they use the same extruder setup!
  • To implement the option for a grid of suport material used in many other slicers
  • Change Filament and Bed Tempertures. No two spool from differnt manufacturers or even simply differnt colors perfom best at differnt tempertures.
It would also be usefull to be able to build custom print and filament profiles for custom setups. That would bring more of the hobbiest community in touch with this advanced software!
Thanks!
Replies (22)
Message 2 of 23
etfrench
I agree.  I looked at it and couldn't see any way to use it with my custom delta.
ETFrench
Message 3 of 23
Well what I do is use the printrbot print profile for my mendel and I just change the start g-code with the temperatures every time I print something in repetier host. You could try using it with your normal host software, and use the ultimaker profile as your slicer!
Though this software will never be useful for the 3d printing community till one can add custom 3d printer profiles!
Message 4 of 23
sdayanand
Thanks for this feedback.
We will looking into adding the settings you requested - we will discuss this with the development teams.
As far as the grid of supports option goes, that wasn't something we had considered till now. We will discuss this also with our product design teams.
We will update you when we know more.
  -Print Studio team
Message 5 of 23
etfrench
You can edit the temperatures and a few other settings in %appdata%\Local\Autodesk\Print Studio\printDB\materials.json.  I'd make a copy of the file before making changes so you can revert it easily.
Unfortunately none of the printer profiles in printerTypes.json are for deltas, so the X and Y coordinates are in the corner instead of the middle of the bed.
ETFrench
Message 6 of 23
Has there been any progress on this? I'd love to see custom printer setting and profiles too..
regards,
aj
  -Print Studio team
Message 7 of 23
sdayanand
We are currently working on the settings which will be available in our next version (date soon TBD). We will update you on this once the development work is completed.
  -Print Studio Team
Message 8 of 23
Yes this is the feature that is keeping me from using print studio.  I have 3 diffrent printers none of which is supported at the moment.amd I would love to be able to add them.
Message 9 of 23
etfrench
It appears Print Studio has been updated.  Is there a way to create a profile for a delta printer?
ETFrench
Message 10 of 23
scott_mayson
We should also be able to change nozzle diameter! I have Ultimaker with 0.6mm nozzle.
Dr. Scott Mayson
Industrial Design RMIT University, Melbourne Australia
scottmayson.com
Message 11 of 23
etfrench
You can edit the nozzle diameter in the file: %AppData%\Local\Autodesk\Print Studio\printDB\printerTypes.json
It's not a very nice way to have to do it, but it "should" work.
ETFrench
Message 12 of 23
scott_mayson
Thanks that worked easily enough.  There is also another setting in materials.json and profiles.json  to adjust filament dia and nozzle
Dr. Scott Mayson
scottmayson.com
Message 13 of 23
where is the repeater host option i cant find it???
Message 14 of 23
I would like to use Printer Studio with CraftBot printer, but it is not listed amongst default printers, so I am looking for an editor for printerTypes.json file, or an edited version of it.
(I know I can modify it by text editor, but there are some values that I do not know.)
Can someone help me with this?
Tamas
Message 15 of 23
I have not edited this file yet, but it would be good to check this out. I
will respond if I discover how to edit it!
Message 16 of 23
rs29C2H
Community Visitor
Community Visitor
Hi, still no custom printer support yet? 😕
Message 17 of 23
andypugh
Can I ask what the equivalent file is called in the Mac version? (I do know how to look inside App packages)
Message 18 of 23
/Library/AutodeskPrintManager/PrintManager/spark-print-data/printertypes.json
Message 19 of 23
andypugh
Thanks, that led me to a whole new set of files to explore, but hasn't yet found me the place that the steps/mm data is stored (my understanding is that .x3g files are in raw steps, so it is the slicer rather than the printer which needs to know the pulley ratios)
I will report back if I find the place to set the scale.
Message 20 of 23
Sorry, that's the wrong path. You want the files in your user Library for editing:
~/Library/Application\ Support/com.autodesk.spark.printstudio/
But, since Spark has been abandoned there might not be much point.
