When I print from design review or revit to bluebeam my sheets show up blank in bluebeam and only shows 1 blank sheet. But if I print one by one from design review then they show correctly so i can only print one at a time to bluebeam
-thanks for the help
Are you using same paper size / print configuration settings in both trials? You might need to choose an appropriate paper size for your drawing area.
