I've seen several posts on this, but no solutions (at least working solutions). Using C3D 2012, SheetSet, and DR 2013. My drawings (layouts) are all zoom extents; but 2 of 3 sheets in the DWF have an initial view zoomed in on part of the sheet, the other sheet in the DWF is displaying properly a full extents.
Any ideas? This gets very cumbersome and annoying on 400+ page drawing sets.
Could you elaborate some more on your comment?
I have a 50 sheet project. I published it to both PDF and DWF. i did the same procedure with AutoCAD 2020 and AutoCAD Electrical 2020. The PDF comes out fine, all sheets initally displaed at extents. The DWF is ay extents through sheet 29. Sheets 30 through 50 are initally displaed zoomed way in.
Any idea why this is only happening above sheet 29?
@Lee.MalaspinaJMHCX wrote:
...Any idea why this is only happening above sheet 29?
ADR (the topic of this forum) is not AutoCAD/ELEC, and it cannot permanently fix DWFs after creation.
Really? The 1st post in this string is titled DWF Zoom Extents. Silly me, I am having a similar issue in a document created by AutoCAD. I said nothing about wanting to "fix DWFs after creation." i want to "fix it" BEFORE creation, inside AutoCAD. Maybe I need to be on a Studebaker Motor Vehicle forum instead!
So sorry that I bothered you. Silly me.
.... i want to "fix it" BEFORE creation, inside AutoCAD. ....
@Lee.MalaspinaJMHCX You seem to be reading more into posts (and titles) than are really there, and if others made a mistake posting in here, you assume you can do the same somehow.
So, let's recap:
if you need help with AutoCAD/ACADE in creating problem-free DWF files, then you need to move your queries to one of those software's dedicated user forums instead.
Those forums are here
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
and here
https://forums.autodesk.com/t5/autocad-electrical-forum/bd-p/38
This forum is for ADR only, ADR is just a viewer that views DWF files AFTER you create them: it shows what was created by you in the authoring software that created the DWFs. Nothing more, Nothing less.
Now you know what's going on.
So, let's recap:
and here
No, your ESP is not working as well as you think it is. I found this string through a GOOGLE search and responded accordingy, based on the 1st posting. Does that sound plausible to you? It should. I didn't know that I had violated a strict military type protocall that warrants a blindford and cigarette. My only "mistake" was expecting some input without the usual blatant negativity that is the norm for people today. This isn't FACEBOOK so I will spare you a return on your sarcasm. I will try not to make the mistake of asking you anything in the future. Thank you for your assistance and links to other forums!
@mc5fan wrote:
...I found this string through a GOOGLE search and responded accordingy, based on the 1st posting....
And I bet it had nothing to do with ADR as noted several time now 🙂
You obviously are "no comprende" plain english and just want to argue an insignificant point. I don't get your mindset and do not want to. Sorry that I am not a know everything, genius like you. As I explained earlier, I did not specify ADR in my search, yet, I was brought here.
I did not research the damned string and it's category. I suppose that makes me a totlal moron, in your eyes. So be it. Have fun in your delusion of grandure. I hope it pacifies your conceit. Is there anything other pointless subject that you would like to argue about? I would rather not. I have better things to do. Please respond if you MUST have the last word!
I realize of your line. Whenever i find out People today accommodate getting some almost all believe that it is very difficult so that you can placed this review.
