Hi all,
We have noticed and confirmed by internet searching that for the best use of Design Review software we need to have it and DWG Trueview installed in the same version.
The Issue we are getting is that DWG Trueview is currently in version 2021, but the most recent version of Design Review is 2018. And as we use a cloud solution is not BIM360 (from autodesk) but we intended to continue making markups and other publishing tasks through Design Review, we are having troubles.
So, is Autodesk about to publish an upgrade of Design Review or its gonna remain in the 2018 version and to be discontinued? What are the plans of Autodesk for the Design Review Software?
Thanks in advance,
Solved by pendean. Go to Solution.
If you get 2018 be sure to run it and get the patch if suggested first run. Last time I downloaded Autodesk had not patched the download. You can use the downloaded package on other machines after install.
