Change the measurement tool font size
When I use the measure tool in design view the dimension font size is too small to read clearly.
How can I increase the font size.
See attached example.
I am using Design Review 2013, Autodesk 2014 product design suite and Vault Prof2014.
You can change it before you place the annotation (change the default) or after placement.
To change the default, select the toll you want to change, and in the 'formatting' tab of the 'Markup & Measure' you can change the text size, font, lineweight, etc.
Hope this helps.
To change the text size of Temporary dimensions or measure text size:
Go to File: Options: Graphics: and at the bottom under Graphics there is a text size setting….Have at it.
