autodesk design review update
memoalcr
memoalcr
Autodesk,
Autodesk Design Review is a valuable tool for my work. When are you planning to update since the last known version is 2013? I am having trouble using it in Windows10 OS and there are some issues withe DWG True View 2017
rkmcswain
See this. It contains pointers back to this forum explaining the situation.
memoalcr
I wasn't aware.
However, what happens when you have to work off-line?
From what I just saw, I don't see markup tools for reviewing drawings; correct?
rkmcswain
You'll have to read the entire forum thread referenced in that post.
Scott Sheppard addresses many questions such as that, in the forum thread.
memoalcr
Thank you
The program selects de "Simple Cases" option.
If I click the OK button a "Value out of limits" warning displays right after.
For the selected member the "Loads" window is empty.
If I run the calculations, a "Calculations Errors" window displays with the following message:
"Code combinations: Simple load cases have not been defined"
how to fix this problem
