The title says it all, almost!
I would like to take these courses to prepare for a certification "Autodesk Certified Expert" for Multi-Axis milling.
BUT, on this page (link below) both "Get Started" buttons lead to a 404 error, page not found.
Fusion 360 CAM for Multi-Axis Milling Expert Resources | Autodesk
So, where are these courses, in fact ? Or, if there are different resources to prepare for this certification, where are they ?
Thanks for your help,
Bernard
Solved by CGBenner. Go to Solution.
@bernard5BABD
This appears to be fixed now, I just checked a while ago and the links are working again.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
yes, it's working now. Thank you!
