Our company is still using the Configurator on a daily basis.
As a direct replacement our Autodesk reseller is currently working on an API!
Although it is a positive thought that this will be ready on time for July, I can see a lot of potential problems.
Is the drop dead date of July reality? Or can the channels be left open until say Christmas?
Solved by scott_anderson-adsk. Go to Solution.
The current end of life plan is May 2023.
Hi Scott
Thanks for this info, takes the pressure off a bit!
How will this actually work?
Do we have to spend more ie extend our license until May 2023?
Or is the case as I have read on other posts here, until all of our credits are consumed?
Thanks Again
