Configurator 360 Forum (Read Only)
Welcome to Autodesk’s Configurator 360 Forums. Share your knowledge, ask questions, and explore popular Configurator 360 topics.
Lots of Errors
2 REPLIES 2
D0UGLAS
1031 Views, 2 Replies
Lots of Errors
Suddenly getting lots of errors!
The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it is in the Faulted state.
Exception in function iv_updateAssemblyParameters [Root.theKid]
Exception in iLogic Rules: Exception in the iLogic rule named: 10_TOUS, in document: GA01.iam:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\2aznoci1.dll'.
File name: 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\2aznoci1.dll'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Microsoft.VisualBasic.VBCodeGenerator.FromFileBatch(CompilerParameters options, String[] fileNames)
at System.CodeDom.Compiler.CodeCompiler.FromSourceBatch(CompilerParameters options, String[] sources)
at System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromSourceBatch(CompilerParameters options, String[] sources)
at Autodesk.iLogic.Exec.AppDomExec.CompileCodeHere()
at Autodesk.iLogic.Exec.AppDomExec.CompileCodeInOtherDomain(AppDomain otherDomain, String codeName, String codeText, Boolean checkUnsafeCode)
at iLogic.RuleEvalContainer.ExecRuleCompile(String execRule)
Exception in the iLogic rule named: C360_OnPublishBIM, in document: GA01.iam:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\2tg2rd5z.dll'.
File name: 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\2tg2rd5z.dll'
Exception in the iLogic rule named: PDC, in document: GA01.iam:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\e51tqefi.dll'.
File name: 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\e51tqefi.dll'
Exception in the iLogic rule named: QTE, in document: GA01.iam:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\axtgvaji.dll'.
File name: 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\axtgvaji.dll'
Exception in the iLogic rule named: BOM, in document: GA01.iam:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\ponkmi0v.dll'.
File name: 'D:\Temp\1691C4595EC8C09\szylfmq0.lr0\Temp\ponkmi0v.dll'
Exception in iLogic Rules: Exception in the iLogic rule named: TYPE, in document: ER.ipt:
System.IO.FileNotFoundException: Could not find file 'D:\Temp\168F801537EE10E\okh2qhr0.wxp\Temp\o4ze3ple.dll'.
File name: 'D:\Temp\168F801537EE10E\okh2qhr0.wxp\Temp\o4ze3ple.dll'
The Inventor process or supporting software terminated unexpectedly. Please report this error. So that we can provide the best assistance, please include the URL of your design, the version number, the steps required to reproduce the error, and this tracking ID: '3dd59d19-17eb-4673-8b39-09ed9d043cf5'.
2 REPLIES 2
I'm not sure what happened here but it seems there was a problem with one of our worker servers. I've started new ones so let me know if you still have the issue.
Scott Anderson
Principal Software Engineer
Many thanks Scott let's see what happens today.
