Configurator 360 Forum (Read Only)
Welcome to Autodesk’s Configurator 360 Forums. Share your knowledge, ask questions, and explore popular Configurator 360 topics.
Embedding on a Website
5 REPLIES 5
1579 Views, 5 Replies
How can I embed autodesk 360 on a website. I have figured out how to do it 5 years ago, because iframe could be used from share. How can I do now? I need to do it now on trimmer 2021 website
5 REPLIES 5
scott_anderson-adsk
You can find embedding documentation here: http://help.autodesk.com/view/CFG360/ENU/?guid=GUID-EC3DBA1C-A9B4-43DB-8950-DA51F8E8F58C.
However, you should look into migrating to forge since this service will be retired when all subscriptions expire (See https://www.autodesk.com/products/configurator-360/overview).
See this post for an example for migrating to forge: https://forums.autodesk.com/t5/configurator-360-forum/example-for-migrating-to-forge-design-automati....
Scott Anderson
Principal Software Engineer
maxmarrie
Thank You scott.. I will check all of these guidelines to embed it with my website mailpro that you have mentioned above. If I face any issue then I will do contact with you.
kleinmanmarlene5
Can't embed a video on website.
garrygoldberg1
Web developers must be familiar with the latest technology and be able to showcase their skills. Freelance and pro-bono work are a good way to refine their skills. This will also provide them with a variety of projects. In addition to this, web developers can move up to the next level by taking on new projects  mlsdev.com/services/mobile-app-development
thank you for the guidelines.
